12 years agoQuestion...
Hello, please advise me. Imagine I have 4 registers: regA, regB, regC and regD, all defined as "reg [7:0] regA;". In addition to addressing these registers separately, I need to "assemble" them...
12 years agoAs I suggested before, IMHO the best solution is using a case statement which selects the right registers pairs (and possibly the required operation) depending on regselect.
The operation: regArr16[regselect16[1:0]][15:0] <= regArr16[regselect16[1:0]][15:0] + 16'b1; Must be written extensively, something like this: case(regselect16[1:0]) ... 2'b00 : begin if (regA == 8'hFF) regB <= regB + 8'h1; regA <= regA + 8'h1; end 2'b01 : begin if (regC == 8'hFF) regD <= regD + 8'h1; regC <= regC + 8'h1; end ... endcase Remember that HDL is not a sequential programming language but a description of hardware behaviour. So, a register can be assigned only by a single process. If I understood correctly and considering the example you posted, you can't assign the same physical register considering in one place regselect8 and in another regselect16: you must have a single process where all conditions must be evaluated and assignments must be made inside non overlapping cases. Sorry I can't explain it in a clearer way right now. Maybe you can start writing some code and I would give advice.
