12 years agoQuestion...
Hello, please advise me. Imagine I have 4 registers: regA, regB, regC and regD, all defined as "reg [7:0] regA;". In addition to addressing these registers separately, I need to "assemble" them...
12 years ago --- Quote Start --- wire regArr[31:0]; assign regArr = { regA, regB, regC, regD }; Please excuse me if my questions seem stupid... I am completely lost in it. --- Quote End --- This way you define regArr as an array or 32 single bit wires If you want a single 32bit wire vector you should write: wire [31:0] regArr; assign regArr = { regA, regB, regC, regD }; I'm not sure, but i think Quartus Verilog compiler also supports this syntax: wire [7:0] regArr [0:3]; assign regArr[0] = regA; assign regArr[1] = regB; assign regArr[2] = regC; assign regArr[3] = regD; which is more similar to what you asked in the original post. Please note that with this method you transfer registers data into regArr but you can't use regArr as a register. Then the following operation is illegal regArr[2][7:0] <= regArr[2][7:0] + 8'd1;
