leonardo_forum's avatar
leonardo_forum
4 years ago
Questa Starter Edition bad license file generated
I just generated a license with the Self-Licensing service but is not working.
This is the error I get when I try to start Questa
Fatal License Error
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
OK
This is the output of the utility
C:\Windows\system32>lmutil lmdiag
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
FlexNet diagnostics on Sat 4/9/2022 13:39
License file: C:\intelFPGA\LR-077522_License.dat
The license file is correctly setup, this is the content
# Intel Corporation Software and/or Intellectual Property License File
# Issued 08 April 2022
# Upgrade to these products will no longer be available after the Maintenance Expiration
# date unless licenses are renewed.
# Fixed Node License
# Primary Machine Name-NUC8i5
# Primary Machine ID-NIC ID *****MYNIC*****
# Companion ID-N/A
# Companion ID 2-N/A
# Product License Summary:
# Questasim*-Intel® FPGA Starter Edition, 1 Seat(s)
# - Maintenance Expiration of 2023.04
# - License Expires 08-Apr-2023
# FEATURE START
# This is license file for Questasim*-Intel® FPGA Starter Edition
# Number of seat licenses is 1
# License Expires 08-Apr-2023
# FEATURE END
# End of Intel Corporation Software and/or Intellectual Property License File. Issued 04/08/2022
Where *****MYNIC***** is the NIC. What can I do to fix the issue?
  • harald25's avatar
    harald25
    I have the same problem as well. I am trying to get this running on a RedHat 9 VM that I am running on my Mac via VMWare Fusion.
    I've generated the license twice (yesterday, and today) and they look exactly the same:
    # Issued 12 December 2024
    # Primary Machine Name-rhel_vm
    # Primary Machine ID-NIC ID 000C296B6D6A
    # Companion ID-N/A
    # 3 Questa*-Intel® FPGA Starter Edition (License: SW-QUESTA), 1 Seat(s)
    # - Maintenance Expiration of 2025.12
    # - License Expires 12-Dec-2025
    # FEATURE START
    # This is license file for Questasim*-Intel FPGA Starter Edition
    # License Expires 12-Dec-2025
    300 Your contract does not allow you to use this license type.: u
    # FEATURE END
    # End of Intel Corporation Software and/or Intellectual Property License File. Issued 12/12/2024
    Output when I try to run 'vsim':
    Unable to checkout a license. Make sure your license file environment variable (SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, LM_LICENSE_FILE)
    Unable to checkout a license.  Vsim is closing.
    ** Error: Invalid license environment. Application closing.
    Output when I run 'lmdiag':
    lmdiag - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
    FlexNet diagnostics on Fri 12/13/2024 07:45
    License file: /opt/intelFPGA/license.dat
    Output when I run 'lmgrd':
    7:44:35 (lmgrd) -----------------------------------------------
     7:44:35 (lmgrd)   Please Note:
     7:44:35 (lmgrd)
     7:44:35 (lmgrd)   This log is intended for debug purposes only.
     7:44:35 (lmgrd)   In order to capture accurate license
     7:44:35 (lmgrd)   usage data into an organized repository,
     7:44:35 (lmgrd)   please enable report logging. Use Flexera's
     7:44:35 (lmgrd)   software license administration  solution,
     7:44:35 (lmgrd)   FlexNet Manager, to  readily gain visibility
     7:44:35 (lmgrd)   into license usage data and to create
     7:44:35 (lmgrd)   insightful reports on critical information like
     7:44:35 (lmgrd)   license availability and usage. FlexNet Manager
     7:44:35 (lmgrd)   can be fully automated to run these reports on
     7:44:35 (lmgrd)   schedule and can be used to track license
     7:44:35 (lmgrd)   servers and usage across a heterogeneous
     7:44:35 (lmgrd)   network of servers including Windows NT, Linux
     7:44:35 (lmgrd)   and UNIX.
     7:44:35 (lmgrd)
     7:44:35 (lmgrd)
     7:44:35 (lmgrd)
     7:44:35 (lmgrd) Server's System Date and Time: Fri Dec 13 2024 07:44:35 CET
     7:44:35 (lmgrd) SLOG: Summary LOG statistics is enabled.
     7:44:35 (lmgrd) license manager: can't initialize:No SERVER lines in license file.
     7:44:35 (lmgrd) License Path: "/opt/intelFPGA/license.dat"
     7:44:35 (lmgrd) FlexNet Licensing error:-13,66
    I've set both SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, and LM_LICENSE_FILE to point at my license file.
    Please give some advice Intel!
  • MiguelAF1's avatar
    MiguelAF1
    I am getting wrong license file. I have tried with different accounts and with different PC and I always get this text in the middle of the license file:
    Is it a temporarily error of the server or is there any problem with my accounts?
    I attach the last license file I got (after three attempts).
  • szerajic's avatar
    szerajic
    Does anybody know how to solve this issue? I'm also getting license files with commented parts only.
    • gtaylormb's avatar
      gtaylormb
      Same issue, my license file contains only comments except for "null" on the line I suspect should contain the license information:
      # Issued 11 January 2024
      # Primary Machine Name-FarmBeastWSL
      # Primary Machine ID-NIC ID 00155D3135BC
      # Companion ID-N/A
      # 2 Questa*-Intel® FPGA Starter Edition (License: SW-QUESTA), 1 Seat(s)
      # - Maintenance Expiration of 2025.01
      # - License Expires 10-Jan-2025
      # FEATURE START
      # License Expires 10-Jan-2025
      null
      # FEATURE END
      # End of Intel Corporation Software and/or Intellectual Property License File. Issued 01/11/2024
      • KeithE's avatar
        KeithE
        I am also having the same issue. My first license I got yesterday worked just fine, however the other 3 license I received appear to have the same Null statement in its row.
  • AR_A_Intel's avatar
    AR_A_Intel
    The license issue is fixed. Kindly regenerate the Questa license again in SSLC.
    • Assisfasf's avatar
      Assisfasf
      I'm also receiving incomplete license files (with commented parts only). I tried to generate licenses more than 10 times, none of them is helpful. FEATURE parts have the same content of this post. Any help is appreciated.
    • qsx's avatar
      qsx
      I'm currently having the same issue with license generation for Questa Starter Edition. I'm about to have 10 students with the same problem tomorrow; any help is appreciated. Thanks!
    • efy's avatar
      efy
      Hi, I'm facing the exact same issue. No signature in the license file for Questa Starter edition. Any help is appreciated.
    AR_A_Intel
    HI
    Thanks for update. could you help request again new Questa license in https://licensing.intel.com/ and try it? I’m suspecting error in license file and report back if error happen with Screenshot of error message and also provide the new Questa license.dat file for checking.
    You can also reply/attach your file in private message.
    • leonardo_forum's avatar
      leonardo_forum
      Hello, I requested multiple times a new license. Everytime is missing the signature so is not recognized.
      I tried fixed and floating license, but I can't get a working license.
      I tried differenct NIC too.
      I can't send you a PM because I can't see any button for this.
    leonardo_forum
    Hello, I setup the variable as always and then I rebooted the machine. See attached picture.
    The License file is bad, the website is generating wrong licenses missing the license signature.
    I get this output by running lmgrd:
    PS C:\intelFPGA\21.1\questa_fse\win64> .\lmgrd.exe -z
    12:45:15 (lmgrd) -----------------------------------------------
    12:45:15 (lmgrd) Please Note:
    12:45:15 (lmgrd)
    12:45:15 (lmgrd) This log is intended for debug purposes only.
    12:45:15 (lmgrd) In order to capture accurate license
    12:45:15 (lmgrd) usage data into an organized repository,
    12:45:15 (lmgrd) please enable report logging. Use Flexera's
    12:45:15 (lmgrd) software license administration solution,
    12:45:15 (lmgrd) FlexNet Manager, to readily gain visibility
    12:45:15 (lmgrd) into license usage data and to create
    12:45:15 (lmgrd) insightful reports on critical information like
    12:45:15 (lmgrd) license availability and usage. FlexNet Manager
    12:45:15 (lmgrd) can be fully automated to run these reports on
    12:45:15 (lmgrd) schedule and can be used to track license
    12:45:15 (lmgrd) servers and usage across a heterogeneous
    12:45:15 (lmgrd) network of servers including Windows NT, Linux
    12:45:15 (lmgrd) and UNIX.
    12:45:15 (lmgrd)
    12:45:15 (lmgrd)
    12:45:15 (lmgrd)
    12:45:15 (lmgrd) Server's System Date and Time: Mon Apr 11 2022 12:45:15 W. Europe Summer Time
    12:45:15 (lmgrd) pid 11620
    12:45:15 (lmgrd) SLOG: Summary LOG statistics is enabled.
    12:45:15 (lmgrd) license manager: can't initialize:No SERVER lines in license file.
    12:45:15 (lmgrd) License Path: "C:\intelFPGA\LR-077522_License.dat"
    12:45:15 (lmgrd) FlexNet Licensing error:-13,66
    See first post for the content of LR-077522_License.dat, but essentially is missing lines with
    FEATURE .... HOSTID="..." TS_OK SIGN="..."
    and is not recognized as a valid license
    AR_A_Intel
    Hi
    Could you help re-confirm your environment variable setup again? You need to set your LM_LICENSE_FILE environment variable to point to the license that Intel provides. c:\intel\license.dat or something similar.
    You can refer to link on how to set environment variable.
    To make this entry, you may perform a windows Search for "System Variables" and then click on "Edit the System Environment Variables" and then click "Environment Variables". Be aware that you must add the entry in System variables, not user variables.
    https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/environment-variables.html
    Specifying the License for the Questa
    https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/specifying-the-license-for-the-software.html
