leonardo_forum
4 years agoQuesta Starter Edition bad license file generated
I just generated a license with the Self-Licensing service but is not working.
This is the error I get when I try to start Questa
--------------------------- Fatal License Error ----...
harald25
1 year agoI have the same problem as well. I am trying to get this running on a RedHat 9 VM that I am running on my Mac via VMWare Fusion.
I've generated the license twice (yesterday, and today) and they look exactly the same:
# Intel Corporation Software and/or Intellectual Property License File # Issued 12 December 2024 # Upgrade to these products will no longer be available after the Maintenance Expiration # date unless licenses are renewed. # Fixed Node License # Primary Machine Name-rhel_vm # Primary Machine ID-NIC ID 000C296B6D6A # Companion ID-N/A # Companion ID 2-N/A # Product License Summary: # 3 Questa*-Intel® FPGA Starter Edition (License: SW-QUESTA), 1 Seat(s) # - Maintenance Expiration of 2025.12 # - License Expires 12-Dec-2025 ################################################################################ # FEATURE START # This is license file for Questasim*-Intel FPGA Starter Edition # Number of seat licenses is 1 # License Expires 12-Dec-2025 300 Your contract does not allow you to use this license type.: u # FEATURE END ################################################################################ # End of Intel Corporation Software and/or Intellectual Property License File. Issued 12/12/2024
Output when I try to run 'vsim':
Unable to checkout a license. Make sure your license file environment variable (SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, LM_LICENSE_FILE) is set correctly and then run 'lmutil lmdiag' to diagnose the problem. Unable to checkout a license. Vsim is closing. ** Error: Invalid license environment. Application closing.
Output when I run 'lmdiag':
lmdiag - Copyright (c) 1989-2019 Flexera. All Rights Reserved. FlexNet diagnostics on Fri 12/13/2024 07:45 ----------------------------------------------------- License file: /opt/intelFPGA/license.dat -----------------------------------------------------
Output when I run 'lmgrd':
7:44:35 (lmgrd) ----------------------------------------------- 7:44:35 (lmgrd) Please Note: 7:44:35 (lmgrd) 7:44:35 (lmgrd) This log is intended for debug purposes only. 7:44:35 (lmgrd) In order to capture accurate license 7:44:35 (lmgrd) usage data into an organized repository, 7:44:35 (lmgrd) please enable report logging. Use Flexera's 7:44:35 (lmgrd) software license administration solution, 7:44:35 (lmgrd) FlexNet Manager, to readily gain visibility 7:44:35 (lmgrd) into license usage data and to create 7:44:35 (lmgrd) insightful reports on critical information like 7:44:35 (lmgrd) license availability and usage. FlexNet Manager 7:44:35 (lmgrd) can be fully automated to run these reports on 7:44:35 (lmgrd) schedule and can be used to track license 7:44:35 (lmgrd) servers and usage across a heterogeneous 7:44:35 (lmgrd) network of servers including Windows NT, Linux 7:44:35 (lmgrd) and UNIX. 7:44:35 (lmgrd) 7:44:35 (lmgrd) ----------------------------------------------- 7:44:35 (lmgrd) 7:44:35 (lmgrd) 7:44:35 (lmgrd) Server's System Date and Time: Fri Dec 13 2024 07:44:35 CET 7:44:35 (lmgrd) SLOG: Summary LOG statistics is enabled. 7:44:35 (lmgrd) license manager: can't initialize:No SERVER lines in license file. 7:44:35 (lmgrd) License Path: "/opt/intelFPGA/license.dat" 7:44:35 (lmgrd) FlexNet Licensing error:-13,66
I've set both SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, and LM_LICENSE_FILE to point at my license file.
Please give some advice Intel!
