10 years agoQuartusII doesn't auto assign pins for CycloneV
Hi, I am new to the FPGA world and am currently using Quartus II 12.0. I am working with the Cyclone V device. I need the tool to auto assign the pins and i should be able to see the location...
10 years agoDoes Quartus generate a .sof programming file for you? I've never known Quartus not to produce a .pin file if you get a .sof.
If you can't see the 'Fitter Location' column, enable it. --- Quote Start --- If it's not visible, right-click on a column heading and add the Fitter Location column to the table. --- Quote End --- Cheers, Alex
