10 years agoQuartusII doesn't auto assign pins for CycloneV
Hi, I am new to the FPGA world and am currently using Quartus II 12.0. I am working with the Cyclone V device. I need the tool to auto assign the pins and i should be able to see the location...
10 years agoHi,
I dont see the "fitter location" among all the other options. The .pin file is not getting generated and also thefit.rpt file assigns the signal to pads. Eg: +------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------+ ; Input Pins ; +----------------------+-------------+----------+--------------+--------------+--------------+-----------------------+--------------------+--------+-----------------+----------+--------------+--------------+-------------+---------------------------+----------------------+ ; Name ; Pin# ; I/O Bank ; X coordinate ; Y coordinate ; Z coordinate ; Combinational Fan-Out ; Registered Fan-Out ; Global ; PCI I/O Enabled ; Bus Hold ; Weak Pull Up ; I/O Standard ; Termination ; Termination Control Block ; Location assigned by ; +----------------------+-------------+----------+--------------+--------------+--------------+-----------------------+--------------------+--------+-----------------+----------+--------------+--------------+-------------+---------------------------+----------------------+ ; ADC_DIN ; X66_Y81_N74 ; 7A ; 66 ; 81 ; 74 ; 1 ; 0 ; no ; no ; no ; Off ; 2.5 V ; Off ; -- ; Fitter ; ; CONTACT_START_DIG_IN ; X64_Y0_N34 ; 4A ; 64 ; 0 ; 34 ; 1 ; 0 ; no ; no ; no ; Off ; 2.5 V ; Off ; -- ; Fitter ; Any idea what can be done to make the tool assign properly? Am I missing any settings? Kindly help. Thanks in advance. Sanjana
