17 years agoQuartus8.1 Warning: A strange waring
Recently when I open a revision project in Quatus 8.1,which I founded in the Quartus7.2,there is a strange waring appears: Warning: Some pins have incomplete I/O assignments. Refer to the I/O Assi...
17 years agoThe incomplete I/O warnings are not listed with the other warnings. You manually need to go into the fitter report and select "I/O Assignment Warnings report". You should then see the list of missing assignments.
