16 years agoQuartus TimeQuest TA
Hi, I have some clock muxes in the design and am using Stratix-IV GT. The Fitter automatically places the input clocks and output clocks of that clock mux in different clock tree. Thus resulting i...
16 years agoHi Rysc,
Even if one doesn't use "get_clocks" in the "set_clock_groups", it automatically considers it. One can in fact check the actual command running at the console pane of TimeQuest Timing Analyzer. My issue is that I am having a clock mux, where the inputs are generated from transceiver PLL's, and hence I can find them in "[get_clocks *]" collections. This collection displays all the pins with type {clk} which is a must for all the commands that work on clocks, e.g- set_clock_groups. But I am not able to find the clock mux output in the collection [get_clocks *] and hence am not able to use "set_clock_groups" or "set_false_path" over the output clock. I am finding large skew b/w input and output clocks of this concerned clock mux, since Quartus puts them into different Clock Tree (Finding - All clock mux output going to GLOBAL clock tree). To reduce the implication of these large skew, I have added Phase Compensation FIFO's b/w the input and output clocks of the concerned clock mux. Since Phase Compensation FIFO has some controls that needs to be synchronized from one clock domain to another, I should use false path in such synchronization logic. Again, I can get the object ID of the clock mux output clock and am stuck with large setup as well hold violations. Please suggest a work-around either in design or in the tool/sdc. Thanks Manish
