10 years agoQuartus time-limited to normal evaluation licence
hi I'm a vhdl developer and use frequently the quartus compile. This weekend is expired the evaluation licence for the Quartus II (my version is 15.0) and I've supplied the time-limited licence d...
10 years ago --- Quote Start --- You can check the IP cores Summary to find out exactly which core in your design requires a license. Then you can check in the License Setup window if the license is properly installed. In Quartus 11.1 (and most probably in most recent versions of Quartus), the IP Cores Summary can be found in the Compilation Report > Analysis & Synthesis > IP Cores Summary. The License Setup window can be called from the Tools menu. --- Quote End --- Useful info to take note. Thank you.
