Quartus Support for Post Route Simulations
- 3 years ago
If you mean a post-fit timing analysis, then yes, but I presume you are referring to a true gate-level simulation. This was possible in the past, but newer larger devices have made it such that it's usually impractical to do this (hours or days to run the sim), so gate-level simulation models are not provided. The combination of a functional simulation and timing analysis is usually considered sufficient for verification.
Additionally, timing simulation is not supported for Arria V, Cyclone V, Stratix V, and newer families. If your device does not support timing simulation, use the Timing Analyzer rather than gate-level timing simulation.
Gate-level timing simulation is supported only for the Arria II GX/GZ, Cyclone IV, MAX II, MAX V, and Stratix IV device families.
Reference: https://www.intel.com/content/www/us/en/docs/programmable/683080/22-1/simulation-levels.html
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
