11 years ago
quartus_sh does not run from Tcl Console, but can be run cmd line
my problem is that I can not run quartus_sh from Tcl Console (invalid command name "quartus_sh"), but it works from cmd line. The path to the 'bin' added to PATH variable. I use Quartus 14.0. Cannot find any solutions in the forum.
Do you know how to solve the problem?
    --- Quote Start ---
    ... To do it I set "set_global_assignment -name PRE_FLOW_SCRIPT_FILE quartus_sh:some_script.tcl" in tcl console ...
    --- Quote End ---
    Works for me. You have to put this line into your project's .qsf file, not into the tcl console.
    --- Quote Start ---
    --- Quote End ---
    I encountered the same problem also. Has anyone got the solution? Please help
    No, I want to run some_script.tcl before compilation. To do it I set "set_global_assignment -name PRE_FLOW_SCRIPT_FILE quartus_sh:some_script.tcl" in tcl console.
    But there is no effect from setting the assignment. Now I see that quartus_sh does not work at all:
    quartus_sh
    Error:invalid command name "quartus_sh"
    Error: while executing
    Error:"unknown_original quartus_sh"
    Error: ("eval" body line 1)
    Error: invoked from within
    Error:"eval unknown_original $cmd $args"
    Error: (procedure "::unknown" line 7)
    Error:"quartus_sh"
    But there is no problems with running quartus_sh from command line...
    Felixipg,
    Are you trying to get the DSE feature working?
    -Trukng
