Niko3
3 years agoQuartus II simulation: missing max3000a_ver and output pin stuck at ground
Hi, I am a beginner with Quartus. I use Quartus II 13.0sp1 because I want to use a chip from MAX3000A family. Later versions don't support MAX3000A. To start with a simple design I tested the follo...
SyafieqS
3 years agoDid you see any modelsim ini file generated using the max3000?
Can you try to delete and recompile, and rerun the simulation.
If still persist, seem there is library issue which probably need to resintall.
You can download the device support in here
Reinstall the whole device package with Quartus.
Let me know the update
