Niko3
3 years agoQuartus II simulation: missing max3000a_ver and output pin stuck at ground
Hi, I am a beginner with Quartus. I use Quartus II 13.0sp1 because I want to use a chip from MAX3000A family. Later versions don't support MAX3000A. To start with a simple design I tested the follo...
SyafieqS
3 years agoWhat Quartus Edition are you using? Pro, Std/Lite?
FYI, In Std/Lite, I remember there is a feature to convert from schematic to hdl.
You may use that if applicable.
Anyways glad that you resolve the issue.
Niko3
3 years agoI am using Quartus II 13.0sp1.
The problem with
Error: (vsim-19) Failed to access library 'max3000a_ver' at "max3000a_ver"
still is unresolved.
Where can I get the library max3000a_ver from, for simulation?
