Niko3
3 years agoQuartus II simulation: missing max3000a_ver and output pin stuck at ground
Hi, I am a beginner with Quartus. I use Quartus II 13.0sp1 because I want to use a chip from MAX3000A family. Later versions don't support MAX3000A. To start with a simple design I tested the follo...
FvM
3 years agoHello,
you don't consider that Quartus synthesis performs logic minimization. Respectively your asynchronous pulse generation logic is discarded during synthesis. Read Quartus software manual about syn_keep attribute. Applying the attribute to intermediate logic nodes should synthesize the logic as intended. Not sure if the delay is sufficient to generate a stable output pulse, but something of this kind should work.
Niko3
3 years agoThank you, I will check it.
