10 years agoQuartus II project included files removed from QSF
I've recently had two issues where all of my Quartus II included project files are removed from the QSF file. The latest occurence happened after adding a new STP file to the project. I went to recom...
10 years agoIf you dont have it in a revision control tool or made a backup manually yourself, then you will have to manually add them again.
You might be better off copying the lines that include the source files to the project into a .qip file and then just add the .qip file to the project instead, although this will mean you need to control the adding/removing of files via a text editor and not the gui.
