16 years agoQuartus II bug
I think I found a bug in Quartus II (version 9) or the software works that way. So, I may be wrong, but here is the thing. Every time I compile a project the software makes a new process (a w...
16 years agoWhat's the process? (quartus is the gui, while each part of a compile is a separate one, like quartus_map, quartus_fit, etc.) I run a ton of projects on a laptop, and they close nicely each time. What you're seeing is by no means the norm. If no one else responds with the same issue(and a fix), you might want to open a Service Request on altera.com.
