AGofs
3 years agoQuartus II 18.1 lite edition in system memory editor
Good afternoon , I'm working with 18.1 lite edition with my new FPGA design. I can program FPGA successfully, and then I'm opening InSystem Memory Editor . JTAG ready and USB-Blaster found. I ...
ShengN_altera
2 years agoHi,
Have you properly timing constraint the jtag? Template can be found by go to Insert Template -> Timing Analyzer -> SDC Cookbook -> Jtag Signal Constraints.
Or may be try to lower the programming frequency.
Sheng
- AGofs2 years ago
Hi Sheng,
I will check this issue, but I always used default constraints- and it works.
