Quartus II 18.1 lite edition in system memory editor
So in the IP Parameter Editor for the RAMs in your design, you've enabled ISMCE, specified a unique index name for each instance, compiled the design, and programmed the device. Have you tried programming the device from within the JTAG Configuration section of the ISMCE instead of the Quartus Programmer?
- AGofs2 years ago
Good morning,
I've tried to program my device from JTAG Configuration section of the ISME- sometimes it programs my device properly, but rarely (approximately 1 from 10 trials).
"programs my device properly"- means I've seen rising at the current consuming.
all another trials- any rising at the current consuming after device has been programmed.
in addition, when I'm using an "auto-detect" option at the programmer- it also programs my device properly, but not every time (approximately 1 from 4 trials).
