Yulquen74
2 years agoQuartus II 13.0.1 and EPM7256AQC208-7
I have a design idea in which the EPM7256AQC208-7 would be a good fit with regards to number of I/O's, logic capacity, voltage levels and speed/delay. However, as I understand this device is only su...
RichardT_altera
2 years agoUnfortunately, this is an unsupported device, and technical support will not be provided.
All parts in MAX7000A devices are phased out from Quartus v13.0sp1, and there are no data files available in it.
While a workaround was suggested in another forum case, it is uncertain whether it will work and you will have to bear your own risk.
It is recommended to choose a device listed in the Quartus to ensure the device is compatible.
Richard Tan
