Yulquen74
2 years agoQuartus II 13.0.1 and EPM7256AQC208-7
I have a design idea in which the EPM7256AQC208-7 would be a good fit with regards to number of I/O's, logic capacity, voltage levels and speed/delay. However, as I understand this device is only su...
roeekalinsky
Contributor
2 years agoYep, I hear ya. Support for 3.3V I/O is still fairly common in modern devices, but long gone are the days of 5V-tolerant I/O and of hand-solderable QFP packages.
To your original question, I did a quick search and came across the thread below. You could try the solution described there of hand-editing your QSF file and see if Quartus 13.0.1 accepts your p/n that way:
Yulquen74
2 years agoThanks, I will check it out!
