Quartus failed to compile Verilog code generated by AOC compiler
When you mention the same error on private server, may I know the step you used and could you share with me your project so that I can duplicate the issue?
I tried Quartus 17.4 and 19.1, but neither of them actually worked. In Quartus 19.1, I sourced the setup scripts to make the ENV variables are set correctly (e.g. INTELFPGAOCLSDKROOT e.t.c), and then I ran `aoc -rtl gems.cl` to generate RTL and change to the work directory. There is a XML file named `board_spec.xml` in the folder, and I just followed the commands in that XML to run the compilation.
For Quartus 17.4, it is almost the same steps, except that I have to use `aoc -c gemm.cl` to generate the RTL. I can share you with source code I have to reproduce the issue (you need to replace the TXT extension with CL). Thanks!
