SXian3
6 years agoQuartus failed to compile Verilog code generated by AOC compiler
Environment: Intel vLab servers quipped with Stratix-10 PAC. Software: Quartus Pro 18.1.2 with patches + acceleration stack d5005_ias_2_0_pv I was trying to compile a simple OpenCL program into ver...
sstrell
6 years agoI don't know if this is the issue, but did you run the aoc command with the typo you have there? It should be "-board".
#iwork4intel
- SXian36 years ago
Thanks for your reply.
That's a typo. I should have run the correct command, because I can see that the correct target board is used in the log from AOC.
