13 years agoquartus_cpf generated jic file differs from GUI generated jic file (from sof).
Tool: Quartus II 32-bit Version 12.1 Build 177 11/07/2012 SJ Full Version I've been successfully using the "Convert Programming File" GUI dialog to convert our sof files to jic, for use with an...
13 years agoMy experience is that at least some of the GUI's Advanced settings are not saved in the .cof file. Did you find something else that causes the GUI result to differ from command line?
