14 years agoQuartus 9.1 sp2
hey does anyone know where i can find quartus 9.1 sp2
really need it quick and cant find it anywhere on the altera site? cheers4 Replies
It looks like a bug in Quartus. Unfortunately this version isn't supported any more.
Did you check with the RTL viewer after analysis and synthesis that the code you wrote was properly synthesized? You don't have any big loop that would generate a lot of logic? - Altera_Forum
hey thanks a bunch guys
i found it but i keep getting this error every time i try to compile a vhdl project " *** Fatal Error: Int Divide By Zero Module: quartus_map.exe Stack Trace: 0x258e4: GEN_MACHINE_INFO::get_cache_size + 0x3b4 (CCL_GEN) End-trace " seen this before? - Altera_Forum
A similar question was posted here:
http://www.alteraforum.com/forum/showthread.php?t=32063 The 'solution' was to look here: ftp://ftp.altera.com/outgoing/release and I see the 9.1sp2 files are indeed in there. Cheers, Dave - Altera_Forum
Hi there,
check here : https://www.altera.com/download/service-packs/sps-web.jsp It said that old version is no longer available for download. I think You should submit a request to download old version. :)
