17 years agoQuartus 8 & NIOS flash problem...
This is the problem I am currently experiencing: I'm using a CYC3 which has : - one IS16LV25616 SRAM - 10ns - EPS16 FLASH - 40 MHz clock I have created a custom memory interface in ...
17 years agohave already resolved the problem? I am stumped upon exactly the same problem as you, except that i am using sumsang sram(2MB,32 data width), and the system works at 75MHz.
i don't konw if you have set the skew. if not, you should try -3.5ns to -1.17ns (2 cycles of read latency):) but when i try to set the snew, it still doesn't work when i download the .jic file into the EPCS16I8.:mad: Does anyone here have ideas about this problem? Thanks in advance
