8 years agoQuartus 17 position of symbol labels different for VHDL and block diagram/schematic
When I create a symbol from a VHDL file, the labels are lined up with the pins properly. (center aligned) But when I create a symbol from a block diagram/schematic file, the labels are below the p...
8 years agoI did not find where I can set the alignment of the labels in the symbol (bsf) editor.
Could you point out where to find it? Trying to move the labels by hand is terrible: Just selecting a label, already moves some labels to another position. Also moving the label to the right position cannot be done as the label snaps to certain grid positions, and no position is certer aligned like in a symbol created for a VHDL file. Even if the Option for the Block/Symbol editor 'Snap to grid (applies only to Symbol Editor)' is unchecked, the labels snap to grid. Also when I try to edit the symbol for a VHDL file, once I move the label, it even cannot be moved back to the original position. (only with undo) When the size of the label outline is changed, the labels move too. Changing the outline back to the original size does not work either. Has anybody ever tried editing a symbol? It does not work for me at all.
