Quartus 13.1 Internal error
Hi
I am using Quartus II 64-Bit Version 13.1.4 Build 182 03/12/2014 SJ Full Version,
and keep on getting the following error during fitting.
Internal Error: Sub-system: U2B, File: /quartus/db/u2b/u2b_translator_cv_hmc.cpp, Line: 1028
Invalid Accessor String: CDB_MEM_IF_TCWL_ENUM::TCWL_1
Stack Trace:
0x126842: U2B_TRANSLATOR_CV_HMC::translate_enum_params_generic + 0x2792
0x12b749: U2B_TRANSLATOR_CV_HMC::convert + 0x319
0x12de69: U2B_TRANSLATOR_CV_HMCPHYINT::convert + 0x319
0x2fab3: FSV_U2B_POSTFIT::check_u2b_configs_for_conflicts + 0x4c3
0x310fb: FSV_U2B_POSTFIT::work + 0x13b
0x1dac97: VPR_QI_FACADE::load + 0x2f97
0x19b6b1: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x185e71
0x1c5d52: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x1b0512
0x1d7cc7: VPR_QI_FACADE::vpr_qi_main + 0x27
0x2de91: fitapi_run_vpr + 0x71
0x1276f: fsv_initialize_fitter + 0x60f
0x13ce4: fsv_initialize_fitter + 0x1b84
0x15774: fsv_initialize_fitter + 0x3614
0x12102: fsv_execute + 0x22
0xbaf0: fmain_start + 0x830
0x1525: Legacy_fitter_Init + 0x4b5
0x2618: Legacy_fitter_Init + 0x15a8
0x2168: Legacy_fitter_Init + 0x10f8
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xc1ff: qexe_ipc_progress_bar_name + 0x12bf
0x11dd6: qexe_get_command_line + 0x1556
0x150d5: qexe_run_tcl_option + 0x585
0x1e03d: qcu_run_tcl_option + 0xb8d
0x156ed: qexe_process_cmdline_arguments + 0x54d
0x15851: qexe_standard_main + 0xa1
0xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f04: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f
0x17033: BaseThreadInitThunk + 0x13
0x52650: RtlUserThreadStart + 0x20
End-trace
Ronen
- SyafieqS
Ronen,
Noted on that. May I know if there is any other concern?
- SyafieqS
Ronen,
Seem to me like a bug internal error. Possible to attach qar project here to be replicated?
- RonenP
Hi
Thanks for your help
I have re-installed the Quartus. (Unfortunately didn't help much)
I have restored my project from a back up and it did the trick.
Now it seems to work fine.
Will try not to modify my IP's for now and hopefully it will stay stable.
Ronen
