15 years agoQsys poor fmax peformance
Hi, I just want to know if somebody has experienced the same issue. I took an old SOPC Bulider design, compiled with Q8.1 for a EP3C25F256C8 device and used Q11 to convert it to Qsys. As SOPC b...
15 years agoConnecting the CPU master to a pipeline bridge and then connecting the bridge to the slaves might help. SOPC Builder and Qsys use different interconnect structures so there will be some system architectures that will achieve a higher Fmax in SOPC Builder but in general Qsys will result in faster systems. With 97% memory utilization that would be the first spot I would look for potential optimizations since that is a fairly heavy utilization of the FPGA RAM blocks which will hinder the fitter. Does your SOPC Builder design also result in 97% memory utilization?
