17 years agoPWM signal problem
Hello, could someone explain a strange problem with PW signal. The signal period is 30 ms, and PW triggers in between 0.7 and 2,2 ms. But, I'v got a problem since the moment the signal...
17 years agoFvM , here is a screen with timing information - 1ms per division.
http://img48.imageshack.us/img48/2120/pulse2.png I have checked the osciloscope probe against a low frequency signal generator and it works fine. I "assume" the attenuation is likely capacitive load sort of high pass filter, but no idea what it could be, because nothing stands in between the pin and probe. Generated 3 khz signal on pin is relativly OK, slightly different code without the prescaler counter. I also tried to drive a small RC servo and such signal just holds it on spot. model. But slightly smaller size RC servo responds and moves corresponding to the signal.
