17 years agoPWM signal problem
Hello, could someone explain a strange problem with PW signal. The signal period is 30 ms, and PW triggers in between 0.7 and 2,2 ms. But, I'v got a problem since the moment the signal...
17 years agoBy the way why are you using a shared variable? It isn't recommended because of its non-deterministic behaviour. You have no way of forcing the execution order of your two processes. You should either merge the two processes, or use a signal.
