17 years agoPWM signal problem
Hello, could someone explain a strange problem with PW signal. The signal period is 30 ms, and PW triggers in between 0.7 and 2,2 ms. But, I'v got a problem since the moment the signal...
17 years agoI don't think tit comes from the VHDL code, it's most likely a hardware problem.
Is the pin soldered correctly? Can you map the signal to another pin and see if you have the same problem?
