16 years agopulse width to serial conversion
Hi I am struggling with my project. The system generates a set of 10 different pulses at the same time and I need to output them sequentially one after the other as a serial stream ,i have t...
16 years ago --- Quote Start --- Pulsewidth is basically an analog signal. Buffering of pulsewidth information and resending it delayed, which is apparently necessary for your design, involves time discretization as a first step. You have to decide about a resolution and have to provide a sufficient fast clock for pulsewidth measurement. You must also specify an supported upper pulsewidth bound. In other words, start with a clear specification. --- Quote End --- Hi thanks for that maybe i need to make it clearer the pulse width i am generating is in my program so for a given digital input i am creating a set of 10 different widths of pulse as per the diagram eg 300us , 800us etc, i need to just have each pulse follow on from each other as a serial output i.e to convert the parallel data to serial conversion. I have tried doing it as as staged ripple counter so when one finishes the next stage starts which works but i need to be able to store the origional data pulse so it will output at the right time when that stage is selected. i hope this makes a bit more sense jan
