16 years agopulse width to serial conversion
Hi I am struggling with my project. The system generates a set of 10 different pulses at the same time and I need to output them sequentially one after the other as a serial stream ,i have t...
16 years agoPulsewidth is basically an analog signal. Buffering of pulsewidth information and resending it delayed, which is apparently necessary for your design, involves time discretization as a first step. You have to decide about a resolution and have to provide a sufficient fast clock for pulsewidth measurement. You must also specify an supported upper pulsewidth bound. In other words, start with a clear specification.
