15 years agoPS Configuration Using a MAX II Device
Altera has a white paper on how to use a MAX device to configure your FPGA in FPP, PS, PPA and Remote System Upgrade modes. http://www.altera.com/literature/wp/wp_max_flash.pdf This white ...
13 years ago --- Quote Start --- could we let the FPGA update the configure file by itself? --- Quote End --- Yes. Once you have an FPGA image programmed into your flash and that FPGA configures correctly, the logic within the FPGA can allow reprogramming of the flash. If you want to be safe, you can create a MAX II controller that checks for multiple images. If you are programming in AS mode, then the serial flash is directly connected to the FPGA EPCS interface, but you can still reprogram it (and you can use multiple images). Cheers, Dave
