HT4
7 years agoPS and JTAG combination
Is there any way I can combine PS configuration and JTAG into one connector only. I have very limit space and not able to consider to separate connectors for each way based on Intel cyclone IV devel...
HT4
7 years agoThanks Anand,
it was really helpful document.
I have one more question:
in Figure 2 in the document you sent, does not talk about pins: nCONFIG, CONF_DONE and nSTATUS connections in MAX10 configuration. I believe I should follow the figure 12 in MAX10 config document https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf in page 35 for these pins. Is that correct?
AnandRaj_S_Intel
7 years agoHi HT,
Yes, We have to follow the figure 12 of max 10 configuration user guide also refer pin connection guidelines.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf
Anand
