17 years agoProtecting EPCS
i posted this in the software forum, but perhaps it's really a hardware issue:
For my project, the EPCS contains all firmware, boot loader & application. The firmware and bootloader will not change, but the application may, so I would like to protect the EPCS areas that contains the firmware & boot loader. The firmware MUST be in the lower area of EPCS otherwise it can't be booted from (I believe). According to cyc_c51014.pdf, only the upper areas of EPCS can be protected, not the lower areas. So I can protect my application but not the firmware&bootloader (or protect everything). Is this correct?1 Reply
--- Quote Start --- i posted this in the software forum, but perhaps it's really a hardware issue: According to cyc_c51014.pdf, only the upper areas of EPCS can be protected, not the lower areas. So I can protect my application but not the firmware&bootloader (or protect everything). Is this correct? --- Quote End --- "the upper areas of EPCS can be protected, not the lower areas." This is the weired thing when i saw this part of the document. Why Altera try to protect the application part, not the default part? Or just our understanding problem?
