kikoss's avatar
kikoss
2 years ago
Program/working on Agilex7 SoC without HPS processor
I am working on the Agilex 7 SoC, I-Series. I was wondering if I can program the FPGA fabric through JTAG with no HPS instance on the project , then using the fpga fabric only
Could you let me know the main steps to follow? For example, if I generate a counter that toggles an external signal, do I need to instantiate any HPS unit on this SoC?
The motivation is that we have many small RTL designs we need to check and the compilation time with HPS is much more longer than compiling the small design only
  • You can ignore it unless you're already using the HPS to program the FPGA after it boots. Or pop out the SD card if you're booting from that.
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hi kikoss,
    We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
  • kikoss's avatar
    kikoss
    ok will try and give a feedback on sunday
    Thx !!
  • kikoss's avatar
    kikoss
    Ok , in this case should I prevent the linux OS to boot ?
    Or , just ignore it and program the FPGA ?
    Thx
    • sstrell's avatar
      sstrell
  • sstrell's avatar
    sstrell
    You don't need to include the HPS in a design. Just treat the device as a standard FPGA.
