14 years agoProgramming with standard usb->serial cable
I recently bought this FPGA from ebay:
www ebay.com/itm/150898941284 But I only noticed (stupidly) now that there is no USB connection on it to program it. I tried a standard USB -> serial cable but Quartus doesn't recognize it. Is it possible to program this board without having to buy a blaster?1 Reply
No, I checked the schematic and you configure the FPGA either via JTAG connector CON 12, while debugging, or you load a configuration in the EPCS4 configuration device U10 via the AS-programming connector CON8.
You can buy a low cost 100% comaptible byteblaster from entner electronics (http://www.entner-electronics.com/tl/).
