13 years agoProgramming multiple devices
Hi, I have a board that is set up for In-System programming using the USB blaster. It contains two EP3C16Q240's and a single EPCS16 for programming the devices. I followed all of the instruc...
13 years ago --- Quote Start --- You need to create a multi-sof POF file. to program the EPCS. In quartus go File->Convert Programming File Here you can create POF file and add your master and slave SOF files to the stream. Pete --- Quote End --- Thanks for your help Pete. I was able to program the EPCS
