Dima7's avatar
Dima7
5 years ago
Programming MAX7000E
Hello!
The device EPM7128ELC84 - 15 does not have an JTAG interface.
How can I program it?
  • JohnT_Altera's avatar
    JohnT_Altera
    I understand but unfortunately we do not have the MPU anymore.
    • ak6dn's avatar
      ak6dn
      That is why I referred to the third party programmer tools. They are available new today and are able to support programming the MAX7000E series parts should someone need to do that.
      I get it that as an Intel employee you only ever recommend an Intel produced solution (ie, the MPU). But that is not always in the best interests of your customers and this is a customer forum.
    JohnT_Altera
    I understand that but unfortunately the Max 700 device is already EOL as well.
    • ak6dn's avatar
      ak6dn
      It is certainly true the MAX7000E series is EOL (ie, can't buy new parts from Intel/Altera) but that does not mean folks don't have either legacy hardware or tube(s) of NOS parts they want to try and use.
    • ak6dn's avatar
      ak6dn
      The Altera PL6/MPU has been obsolete for years. Good luck with that.
  • ak6dn's avatar
    ak6dn
    You will need a third party programmer (like from EEtools or Xeltek, for example) that can program FPGAs using a specific adapter socket for that device (in your case a PLCC 84 package).
    Typical cost new today will be in the $1000 - $1500 range total for programmer and adapter.
    So unless you have a piece of legacy hardware that absolutely requires you using the EPM7128E device, or you have literally hundreds of EPM7128E devices laying around that you need to program, I would recommend you toss those in the recycle bin. It won't be cost effective to use it.
    Go source some EPM7128S devices in PLCC84 that can be programmed by JTAG and get a $50 USB Blaster clone from TerAsic and use that. That is what I do for my EPM7128 based design.
