monk31
6 years agoprogramming flash macronix
Hi ,
i want to program Cyclone |V with macronix flash MX25L3235EM2I-10G
(spi 32 Mb)
Is the good solution is to use Quartus 18.1 Pro edition and add a new config config device ?
Best r...
NurAiman_M_Intel
6 years agoHi,
If you are using Intel Quartus Prime Standard Edition software version 18.1.1 and later, you should be able to proceed without any issue. Try to check what software version are you using?
Aiman
- monk316 years ago
I use quartus prime edition standard 18.1 and the problem is always present
As i showed , on the dialog box "Convert Programming File" , i don't have "..." box (near of Mode text) to add new flash
in cyclone |V and V
- monk316 years ago
Finally i found my problem
I migrated my version to 20.1 and it works
to program a generic flash , you must use 18.1.1 but this version don't exist on the Download Center Intel
this is 18.1.0 that you can download
I save a template xml of my flash , and i want to update my database on the other PC.
how can do it this operation ?
