10 years agoProgramming EPCS16 by microcontroller
Hi alltogether, I am quite new here so maybe the following questions sound very easy for some of you. I use the FPGA EP4C10E2I7 together with the flash EPCS16. The flash can be read/wri...
10 years agoThank you Cris,
today we tried to write a program into the EPCS16 with a .hexout, .rpd and a.rbf-file without any success. The code works when we program the .jic-file into the EPCS16 using the USB-Blaster. With the mirocontroller we are able to erase the flash and we can also write the hexout-, rpd- and rbf-files and read these files from the flash. What else can be the reason why it does not work with any of these files? Would be very nice if someone of you knows any solution or can give us a hint! Thank you. Best regards, Patrick
