10 years agoProgramming EPCS16 by microcontroller
Hi alltogether, I am quite new here so maybe the following questions sound very easy for some of you. I use the FPGA EP4C10E2I7 together with the flash EPCS16. The flash can be read/wri...
10 years agoQuestion 1
You can use any file format your microcontroller is able to process. One of the simplest options is to convert the fpga configuration file into hex format. Question 2 Use the remote update core to trigger a fpga reconfiguration
