11 years agoProgrammer file not update after I recompile the VHDL file
I am working on Cyclone II FPGA EP2C8F256, and using USB-Blaster in JTAG mode to program the .pof or .sof file. Every time after I made some changes to my VHDL code, recompile the project and program...
11 years agoThe Quartus compile command outputs a sof file. If you need a pof file you will need to use the convert programming file command every time you compile and want to run on hardware.
