10 years agoprogram/erase MAX II with TDO disabled?
I think I messed up and bricked my board, but I'm open to ideas. Here's the scenario: My board uses the EPM240 in the 100-pin micro BGA package. There are no other JTAG devices in the chain, ...
10 years agohave you asked board's vendor?
Why did you so?! from MAX II Device handbook: --- Quote Start --- Programming with External Hardware MAX II devices can be programmed by downloading the information via in-circuit testers, embedded processors, the Altera® ByteblasterMV™, MasterBlaster™, ByteBlaster™ II, and USB-Blaster cables. BP Microsystems, System General, and other programming hardware manufacturers provide programming support for Altera devices. Check their websites for device support information. --- Quote End --- i know that in max10 there is separate jtagen pin to distinguish gpio and jtag on the smae pins,but in max2 all jtag pins are dedicated according to handbook.
shoud you paraphrase question like "how to progam device without jtag tdo line in device"
if it possible put you gpio in tristate.
or write your own driver that provide expected values from tdo line to software. so you should return to the first sentence.
