10 years agoprogram/erase MAX II with TDO disabled?
I think I messed up and bricked my board, but I'm open to ideas. Here's the scenario: My board uses the EPM240 in the 100-pin micro BGA package. There are no other JTAG devices in the chain, ...
10 years agoYou may not have 'bricked' your board. However, driving a GPIO into TDO is not the smartest thing to do - I suspect you've realised that now...
With both your GPIO output signal and TDO driving the same net, your Blaster can't make any sense of what it's receiving. You are going to have to cut the track from the GPIO pin to disconnect it from TDO. You must clearly leave the TDO track to your header intact. Hopefully, the drive strength of the GPIO isn't enough to damage the TDO driver. Providing that's the case I'd expect your board to spring back into life. Cheers, Alex
