MDuse
7 years agoProgram not working as expected
Hi, my device consists of MCU, MAX V CPLD and sensor device. MAX V CPLD is used to interface sensor to MCU. I have a code in VHDL for MAX V CPLD: entity Device is
port (
clk16: in std_logic...
JohnT_Altera
7 years agoCould you provide the full code so that I can further understand your code?
- MDuse7 years ago
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity Device is port ( -- SRAM address, data, WE, CE ram_a: out std_logic_vector(14 downto 0); ram_ad: out std_logic_vector(15 downto 0); ram_we: out std_logic; ram_ce: out std_logic; -- ADC data output adc_d: in std_logic_vector(7 downto 0); -- main clock generated by MCU clk16: in std_logic; -- divided clock clk_out: buffer std_logic; -- open drain output with external pull up resistor. Connected to MCU start: inout std_logic; -- reset. Connected to MCU reset: in std_logic ); end Device; architecture b of Device is type T_STATE is (STOPPED, STARTING, DUMMY_PERIOD, SAMPLING, FINISHING, WAITING_FOR_STOP); type T_SAVINGSTATE is (NOTSAVING, SAVING, FINISHINGSAVING); signal cnt: unsigned(9 downto 0); signal address: std_logic_vector(14 downto 0); signal state: T_STATE := STOPPED; signal savingstate: T_SAVINGSTATE := SAVING; -- timing for state machine: constant DUMMY_CLOCKS: integer := 97; constant START_SAVING_CLOCKS: integer := DUMMY_CLOCKS + 5; constant STOP_SAMPLING_CLOCKS: integer := DUMMY_CLOCKS + 512; constant FINISH_SAVING_CLOCKS: integer := START_SAVING_CLOCKS + 512; constant STOP_SAVING_CLOCKS: integer := FINISH_SAVING_CLOCKS + 1; begin process (clk16, clk_out, reset) begin if reset = '0' then address <= (others => '0'); state <= STOPPED; savingstate <= NOTSAVING; ram_a <= (others => 'Z'); ram_ad <= (others => 'Z'); ram_ce <= 'Z'; ram_we <= 'Z'; clk_out <= '0'; start_pulse <= '0'; start <= 'Z'; else if rising_edge(clk16) then clk_out <= not clk_out; end if; if falling_edge(clk16) then if savingstate = SAVING then if clk_out = '1' then ram_a <= address; ram_ad(7 downto 0) <= adc_d; else address <= unsigned(address) + 1; ram_ad(15 downto 8) <= adc_d; end if; elsif savingstate = NOTSAVING then ram_a <= (others => 'Z'); ram_ad <= (others => 'Z'); end if; end if; if rising_edge(clk_out) then case state is when STOPPED => if start = '0' then -- MCU started the job by pulling the line low start <= '0'; -- pull it low to tell MCU the job is in progress state <= STARTING; end if; when STARTING => cnt <= (others => '0'); state <= DUMMY_PERIOD; when DUMMY_PERIOD => cnt <= cnt + 1; if cnt = DUMMY_CLOCKS then state <= SAMPLING; end if; when SAMPLING => cnt <= cnt + 1; if cnt = START_SAVING_CLOCKS then savingstate <= SAVING; elsif cnt = STOP_SAMPLING_CLOCKS then state <= FINISHING; end if; when FINISHING => cnt <= cnt + 1; if cnt = FINISH_SAVING_CLOCKS then savingstate <= FINISHINGSAVING; elsif cnt = STOP_SAVING_CLOCKS then savingstate <= NOTSAVING; state <= WAITING_FOR_STOP; start <= 'Z'; -- job done, release the line end if; when WAITING_FOR_STOP => cnt <= cnt + 1; if cnt = STOP_SAVING_CLOCKS + 100 then state <= STOPPED; end if; end case; end if; if savingstate = SAVING then ram_ce <= cis_cp; elsif savingstate = FINISHINGSAVING then ram_ce <= '1'; else ram_ce <= 'Z'; end if; end if; end process; end b;There is my MAX V that implements this code, ADC that converts data from sensor, MCU and SRAM.
MCU resets or starts the job (reset, start),.
When started, CPLD starts reading data from ADC's 8 bit data bus and saves it to SRAM which has 16 bit data bus.
