11 years agoprogram external nor flash (paralell) through cyclone iv (de0 nano)
Hi! I have a small project in the works involving 4x S29GL064N nor flash (paralell) on the same bus on a pcb. + a suitable fpga to handle the programming if possible.. My goal is to be able t...
11 years agoFPGA is a very high speed thing, Flash is a slow IC. for fpga this task is a piece of cake. if you'l get fpga model with many pins you may communicate with ~8 flash IC-s parallely. open your flash documentation, there will be described something that is called a communication protocol - a set of rules about how to communicate with the flash. i remember i'v studied it in 1-2days so it's very easy. especially if it uses "Common Flash Interface (CFI)" it's a very nicely described protocol with timing diagrams specified in the datasheet.
