13 years ago
Program EPC1 with usb blaster and pof file
i want to burn an old epc1pi8 device
this is what i got:
an old pof file for epc1 device screen: i.imgur*com/uCZcGUH.png
usb blaster
some skills and some components to build up some hardware.
is this possible? what do i need? how does the required cuircit look like?
thx in advance
    easiest way is to look in the datasheet for the enhanced configuration devices. These are programmed via JTAG I/F, thus the circuit would be
    "power, JTAG I/F to Header and usb-Blaster to program"
    --- Quote Start ---
    --- Quote End ---
    thx for your answer, but how do i connect the JTAG I/F to the epc1? it doesnt have the TDI,TCK,TDO,TMS pins. the datasheet does not list the epc1
    Well, sorry, I missed the point (and my designs with the EPC1 are a long time ago)...
    The EPC1 was the last EEPROM which cannot be programmed in-ciruit, i.e. you need to have programmer hardware (as for "standard" ROM) - there is no way to do this with the USB-Blaster itself.. In Ciruit programming started with the EPC2...
    Sorry for confusing
    From the EPC1 Datasheet:
    "Programming support with Altera’s Master Programming Unit
    (MPU) and programming hardware from Data I/O,
    BP Microsystems, and other manufacturers"
