8 years agoProgram Counter Jumping Randomly while debugging?
Hi all, I am using stratix-2 FPGA(EP2S30F484)[/B]and there is no external ram. My elf file size is 170 Kilo Bytes.even if i create small hello world also its giving the same size. If i include...
8 years ago --- Quote Start --- what optimisation level are you using when compiling? it might appear as if the code is stepping out of sequence when debugging with higher levels of optimisation and where you set a breakpoint might get optimised out. --- Quote End --- "I am using -O0 level to support break points other wise it is -Os I am attaching my project sopcinfo the elf file size is 500Kbytes. Can you please reduced to 64KB and send me if possible send me the process also.
